What is your Pride & Joy radio? Owned or wanted...
My pride and joy would have to be the Philco 37-116 which was completed in 2013. I don't think I'll ever part with it. And I have a fantastic Zenith Transoceanic 600, one of the last made that has the phono hookup in the back and the headphone jack in the front. So sensitive and the sound is amazing.
[Image: http://i1281.photobucket.com/albums/a508...30a600.jpg]
Vernon /Ronin61
RE: What is your Pride & Joy radio? Owned or wanted... - by Ronin61 - 02-25-2014, 10:27 AM
RE: What is your Pride & Joy radio? Owned or wanted... - by MiquelonBrad - 03-27-2014, 12:10 AM
Philco 91 Tuning Condenser
