What is your Pride & Joy radio? Owned or wanted...
42-1015....12 tubes with Beam of Light. Production of only 1,255.
Waiting patiently for restoration. I do like the immediate pre-war consoles and this is one of the rarer ones. Love the look!
RE: What is your Pride & Joy radio? Owned or wanted... - by jeffgniffke - 02-25-2014, 11:16 AM
RE: What is your Pride & Joy radio? Owned or wanted... - by MiquelonBrad - 03-27-2014, 12:10 AM
Philco 91 Tuning Condenser
