38-620 Tuning Question
I read somewhere that little conductive 'hairs' can form between the plates, run a business card between them and see if it helps.
38-620 Tuning Question - by Jamie - 02-25-2014, 02:36 PM
RE: 38-620 Tuning Question - by skyscraper - 02-25-2014, 03:53 PM
RE: 38-620 Tuning Question - by exray - 02-25-2014, 07:18 PM
RE: 38-620 Tuning Question - by Jamie - 02-25-2014, 08:59 PM
RE: 38-620 Tuning Question - by morzh - 02-25-2014, 09:29 PM
RE: 38-620 Tuning Question - by Joeztech - 02-25-2014, 10:09 PM
RE: 38-620 Tuning Question - by jerryhawthorne - 02-26-2014, 05:27 PM
RE: 38-620 Tuning Question - by Jamie - 02-26-2014, 11:33 PM
RE: 38-620 Tuning Question - by Mondial - 02-27-2014, 12:57 AM
RE: 38-620 Tuning Question - by Jamie - 03-02-2014, 01:22 PM
RE: 38-620 Tuning Question - by gregb - 03-02-2014, 01:43 PM
There are currently 8912 online users. [Complete List]
» 5 Member(s) | 8907 Guest(s)
AvatarAvatarAvatarAvatar
