4 Radio cabinets finished in one day!
#34
I have used everything from Bix to Zip strip. None will ever compare to my one true love that they stopped making a few years back. I don't have a preference since they all do the same thing really. I usually just get the kleen strip or DIB stripper. As for grain filler I use the Mohawk right now but it can take more than a few coats to get it really finished. Por O Pac is a great grain filler.
RE: 4 Radio cabinets finished in one day! - by OldRestorer - 02-25-2014, 11:07 PM
Philco 91 Tuning Condenser
There are currently 8102 online users. [Complete List]
» 2 Member(s) | 8100 Guest(s)
