116X bakelite block question
As I suspected 0.3uF is I think paralleled two of 0.15uF.
Ground lug is needed in 82 (should be DG) and not needed in 102 (should be DU).
Your pics in post #6 did not show up.
116X bakelite block question - by Tom Hamilton - 02-25-2014, 12:48 PM
RE: 116X bakelite block question - by morzh - 02-25-2014, 01:20 PM
RE: 116X bakelite block question - by morzh - 02-25-2014, 09:32 PM
RE: 116X bakelite block question - by klondike98 - 02-26-2014, 11:22 AM
RE: 116X bakelite block question - by morzh - 02-26-2014, 11:57 AM
RE: 116X bakelite block question - by klondike98 - 02-26-2014, 01:35 PM
RE: 116X bakelite block question - by klondike98 - 02-26-2014, 01:56 PM
There are currently 10587 online users. [Complete List]
» 3 Member(s) | 10584 Guest(s)
