Today's special
Brenda, the way to go is rebuilding. There are lots of NOS around but they are old and personal experiance is they dont dont last as the crystal is fragile at this point due to age. I have West Tech rebuild mine and they work perfect and dont quit a week down the road.
Gregb
Today's special - by BrendaAnnD - 02-26-2014, 11:00 AM
RE: Today's special - by klondike98 - 02-26-2014, 11:07 AM
RE: Today's special - by GarySP - 02-26-2014, 11:34 AM
RE: Today's special - by Mondial - 02-26-2014, 11:50 AM
RE: Today's special - by morzh - 02-26-2014, 11:53 AM
RE: Today's special - by sam - 02-26-2014, 01:03 PM
RE: Today's special - by gregb - 02-26-2014, 01:16 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:20 PM
RE: Today's special - by morzh - 02-26-2014, 03:26 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:41 PM
RE: Today's special - by morzh - 02-26-2014, 03:51 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 08:55 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:17 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:21 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 09:03 AM
RE: Today's special - by sam - 02-27-2014, 12:54 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:49 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:53 PM
RE: Today's special - by sam - 02-27-2014, 03:03 PM
RE: Today's special - by BrendaAnnD - 02-28-2014, 02:01 AM
RE: Today's special - by BrendaAnnD - 02-28-2014, 01:26 PM
RE: Today's special - by sam - 03-01-2014, 10:12 PM
There are currently 5426 online users. [Complete List]
» 4 Member(s) | 5422 Guest(s)
AvatarAvatarAvatarAvatar
