116X bakelite block question
Bob,
I've got the excellent schematic and service notes from Chuck Schwark, but there's no mention of a typo on the parts list for # 82.
Tom
116X bakelite block question - by Tom Hamilton - 02-25-2014, 12:48 PM
RE: 116X bakelite block question - by morzh - 02-25-2014, 01:20 PM
RE: 116X bakelite block question - by morzh - 02-25-2014, 09:32 PM
RE: 116X bakelite block question - by klondike98 - 02-26-2014, 11:22 AM
RE: 116X bakelite block question - by morzh - 02-26-2014, 11:57 AM
RE: 116X bakelite block question - by klondike98 - 02-26-2014, 01:35 PM
RE: 116X bakelite block question - by Tom Hamilton - 02-26-2014, 01:48 PM
RE: 116X bakelite block question - by klondike98 - 02-26-2014, 01:56 PM
