Majestic model 20
You think the 20 is heavy, try a 52 superhet, 54 lbs as I recall.
Majestic model 20 - by Jayce - 02-25-2014, 05:08 PM
RE: Majestic model 20 - by morzh - 02-25-2014, 05:44 PM
RE: Majestic model 20 - by BrendaAnnD - 02-25-2014, 08:31 PM
RE: Majestic model 20 - by morzh - 02-25-2014, 10:06 PM
RE: Majestic model 20 - by NostalgiaRadioTime - 02-25-2014, 10:47 PM
RE: Majestic model 20 - by BrendaAnnD - 02-25-2014, 11:12 PM
RE: Majestic model 20 - by Jayce - 02-25-2014, 11:24 PM
RE: Majestic model 20 - by PhilcoMike - 02-26-2014, 01:26 PM
RE: Majestic model 20 - by Alan Douglas - 02-26-2014, 02:11 PM
RE: Majestic model 20 - by morzh - 02-26-2014, 02:46 PM
RE: Majestic model 20 - by Jayce - 02-26-2014, 04:25 PM
RE: Majestic model 20 - by Alan Douglas - 02-27-2014, 07:14 PM
RE: Majestic model 20 - by Jayce - 02-28-2014, 06:18 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7012 online users. [Complete List]
» 1 Member(s) | 7011 Guest(s)
