Today's special
Morzh,
It's the 46-1201 Code 124. But it definitely has a doubler. Was the first thing I noticed when I pulled the chassis out: three separate 'lytics, two of them wired negative-positive-negative-negative. Was only then I bothered to get the schematic.
Just looked at the 48-1201 in Nostalgia Air. My 46 is much closer to that one electrically, but uses a different tube lineup. It uses a 50Y6 rectifier and a 35L6 output. Red-headed step-child? Icon_smile Interesting though that the schematic in Beitman's just happens to be this particular run.
Today's special - by BrendaAnnD - 02-26-2014, 11:00 AM
RE: Today's special - by klondike98 - 02-26-2014, 11:07 AM
RE: Today's special - by GarySP - 02-26-2014, 11:34 AM
RE: Today's special - by Mondial - 02-26-2014, 11:50 AM
RE: Today's special - by morzh - 02-26-2014, 11:53 AM
RE: Today's special - by sam - 02-26-2014, 01:03 PM
RE: Today's special - by gregb - 02-26-2014, 01:16 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:20 PM
RE: Today's special - by morzh - 02-26-2014, 03:26 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:41 PM
RE: Today's special - by morzh - 02-26-2014, 03:51 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 08:55 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:17 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:21 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 09:03 AM
RE: Today's special - by sam - 02-27-2014, 12:54 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:49 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:53 PM
RE: Today's special - by sam - 02-27-2014, 03:03 PM
RE: Today's special - by BrendaAnnD - 02-28-2014, 02:01 AM
RE: Today's special - by BrendaAnnD - 02-28-2014, 01:26 PM
RE: Today's special - by sam - 03-01-2014, 10:12 PM
There are currently 10787 online users. [Complete List]
» 1 Member(s) | 10786 Guest(s)
