38-620 Tuning Question
PuhPow, in your first statement that the "microphone like noise" was not controllable by the volume control, loud at any setting seems to indicate to me something in the AF amp area or the volume control is not working right? Why at only one end of dial is perplexing to say the least.
I'm confused, as usual.
Jerry
38-620 Tuning Question - by Jamie - 02-25-2014, 02:36 PM
RE: 38-620 Tuning Question - by skyscraper - 02-25-2014, 03:53 PM
RE: 38-620 Tuning Question - by exray - 02-25-2014, 07:18 PM
RE: 38-620 Tuning Question - by Jamie - 02-25-2014, 08:59 PM
RE: 38-620 Tuning Question - by morzh - 02-25-2014, 09:29 PM
RE: 38-620 Tuning Question - by Joeztech - 02-25-2014, 10:09 PM
RE: 38-620 Tuning Question - by jerryhawthorne - 02-26-2014, 05:27 PM
RE: 38-620 Tuning Question - by Jamie - 02-26-2014, 11:33 PM
RE: 38-620 Tuning Question - by Mondial - 02-27-2014, 12:57 AM
RE: 38-620 Tuning Question - by Jamie - 03-02-2014, 01:22 PM
RE: 38-620 Tuning Question - by gregb - 03-02-2014, 01:43 PM
