Philco 37-610
I intend to work on radios when I feel a bit more competent. Right now I'm in the basic learning stage. I'm on line a lot and I'm reading and trying to educate myself somewhat first before I attempt something. I've bought some radios and I'm trying to restrict my purchases to what l hope aren't very ambitious projects. At least at first.
Jim
Philco 37-610 - by Section10 - 02-26-2014, 07:01 PM
RE: Philco 37-610 - by Warren - 02-26-2014, 08:39 PM
RE: Philco 37-610 - by morzh - 02-26-2014, 09:05 PM
RE: Philco 37-610 - by Section10 - 02-26-2014, 10:14 PM
RE: Philco 37-610 - by PAradiogeek - 02-27-2014, 12:00 AM
RE: Philco 37-610 - by Arran - 02-27-2014, 12:43 AM
RE: Philco 37-610 - by LASJayhawk - 02-28-2014, 07:19 PM
RE: Philco 37-610 - by PhilcoJohn - 03-11-2014, 09:18 PM
RE: Philco 37-610 - by Tom Hamilton - 03-16-2014, 08:33 PM
RE: Philco 37-610 - by PhilcoJohn - 03-17-2014, 07:38 PM
Philco 91 Tuning Condenser
There are currently 10439 online users. [Complete List]
» 2 Member(s) | 10437 Guest(s)
