Today's special
The early 46-1201's didn't use that white plastic dial light cover that almost always warps and burns tight to the dial bulb, causing a dark black / brown burn spot in the middle of the dial. My 46-1203 has the same problem with the dial. I haven't looked into replacements, but you may be able to find some suitable white plastic from Mark Oppat?
Today's special - by BrendaAnnD - 02-26-2014, 11:00 AM
RE: Today's special - by klondike98 - 02-26-2014, 11:07 AM
RE: Today's special - by GarySP - 02-26-2014, 11:34 AM
RE: Today's special - by Mondial - 02-26-2014, 11:50 AM
RE: Today's special - by morzh - 02-26-2014, 11:53 AM
RE: Today's special - by sam - 02-26-2014, 01:03 PM
RE: Today's special - by gregb - 02-26-2014, 01:16 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:20 PM
RE: Today's special - by morzh - 02-26-2014, 03:26 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:41 PM
RE: Today's special - by morzh - 02-26-2014, 03:51 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 08:55 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:17 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:21 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 09:03 AM
RE: Today's special - by sam - 02-27-2014, 12:54 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:49 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:53 PM
RE: Today's special - by sam - 02-27-2014, 03:03 PM
RE: Today's special - by BrendaAnnD - 02-28-2014, 02:01 AM
RE: Today's special - by BrendaAnnD - 02-28-2014, 01:26 PM
RE: Today's special - by sam - 03-01-2014, 10:12 PM
There are currently 10328 online users. [Complete List]
» 4 Member(s) | 10324 Guest(s)
AvatarAvatarAvatarAvatar
