4 Radio cabinets finished in one day!
#36
Just for reference, I don't use stripper. I use #0000 steel wool and lacquer thinner. I used it once on a 640 but it does not work well and dries up quickly making removal irritating.If I had a painted radio I would strip.
Grain filler is a MUST. I didn't use it on a radio recently and it looked like a cat ran his claws across it. finish should be flat and smooth. see pics of Halson in page one not grain filled. Luckily it fell off the table and I have to redo it, lol
Kirk
RE: 4 Radio cabinets finished in one day! - by OldRestorer - 02-27-2014, 08:00 AM
Philco 91 Tuning Condenser
There are currently 8582 online users. [Complete List]
» 2 Member(s) | 8580 Guest(s)
