  • 1 Vote(s) - 1 Average
Not receiving all stations on AM
Yes, doing the IF is the part where I could hear a tone with the generator connected directly to the antenna input and no radio antenna. I will have to do some more experimanting and see if I can get a tone when usong the loop antenna on the generator and the radio antenna hooked up. I did try to get a tone on another radio, wasnt much different, although it seemed sometimes I could hear a tone. I think I will try another loop antenna and if that doesnt make a difference I will change the caps in my signal generator and see if it works a bit better. My frequency counter can see the rf signal from the generator, im just wondering if the audio tone isnt strong enough to work . I will try some things this weekend and hopefully make some progress. If anyone has any ideas to try that would be great, thanks.
Not receiving all stations on AM - by Warren - 02-25-2014, 02:38 PM
RE: Not recieving all stations on AM - by Warren - 02-25-2014, 09:40 PM
RE: Not receiving all stations on AM - by Warren - 02-26-2014, 12:28 AM
RE: Not receiving all stations on AM - by Jamie - 02-26-2014, 08:59 AM
RE: Not receiving all stations on AM - by Mondial - 02-26-2014, 11:36 AM
RE: Not receiving all stations on AM - by Warren - 02-26-2014, 03:00 PM
RE: Not receiving all stations on AM - by Jamie - 02-26-2014, 11:28 PM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 12:58 AM
RE: Not receiving all stations on AM - by Mondial - 02-27-2014, 11:07 AM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 06:21 PM
RE: Not receiving all stations on AM - by exray - 02-27-2014, 06:36 PM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 11:05 PM
RE: Not receiving all stations on AM - by morzh - 02-27-2014, 11:17 PM
RE: Not receiving all stations on AM - by Warren - 02-28-2014, 12:26 AM
RE: Not receiving all stations on AM - by Mondial - 02-28-2014, 11:38 AM
RE: Not receiving all stations on AM - by morzh - 02-28-2014, 11:53 AM
RE: Not receiving all stations on AM - by Warren - 02-28-2014, 03:03 PM
RE: Not receiving all stations on AM - by morzh - 02-28-2014, 03:43 PM
RE: Not receiving all stations on AM - by Warren - 03-01-2014, 08:55 PM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 12:26 AM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 09:41 AM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 02:50 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 03:35 PM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 04:15 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 04:41 PM
RE: Not receiving all stations on AM - by Warren - 03-04-2014, 03:18 PM
RE: Not receiving all stations on AM - by Warren - 03-09-2014, 12:31 AM
RE: Not receiving all stations on AM - by Warren - 03-29-2014, 11:53 PM
RE: Not receiving all stations on AM - by Warren - 03-31-2014, 01:39 PM
There are currently 5609 online users. [Complete List]
» 4 Member(s) | 5605 Guest(s)
AvatarAvatarAvatarAvatar
