89 Cabinet
That is the actuall "router attatchment" but its big and bulkey. They sell a smaller "cutting base" with bits (i was at lowes lastnight and looked for the name of it) it is much smaller and easier to handle. If your dremel has the removable cap at the chuck end then it will fit. The router bits come in a pack of six with one bit that matches your grill.
http://www.dremel.com/en-us/Attachments/...px?pid=565
http://www.dremel.com/en-us/Accessories/...px?pid=692
89 Cabinet - by skyscraper - 02-25-2014, 12:02 AM
RE: 89 Cabinet - by Warren - 02-25-2014, 12:51 AM
RE: 89 Cabinet - by tab10672 - 02-25-2014, 01:10 AM
RE: 89 Cabinet - by OldRestorer - 02-27-2014, 10:39 AM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 04:13 PM
RE: 89 Cabinet - by skyscraper - 02-27-2014, 04:39 PM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 10:32 PM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 10:42 PM
RE: 89 Cabinet - by skyscraper - 02-27-2014, 11:50 PM
RE: 89 Cabinet - by tab10672 - 02-28-2014, 12:25 AM
RE: 89 Cabinet - by Jake Blake - 03-10-2014, 08:23 AM
Philco 91 Tuning Condenser
There are currently 8672 online users. [Complete List]
» 3 Member(s) | 8669 Guest(s)
