89 Cabinet
It does unscrew.. Never noticed it before, I've had it for years. The guide looks perfect, thanks so much tab.
Final question for now, is it possible to match the finish on just this piece? The rest of the cabinet is in decent shape.
89 Cabinet - by skyscraper - 02-25-2014, 12:02 AM
RE: 89 Cabinet - by Warren - 02-25-2014, 12:51 AM
RE: 89 Cabinet - by tab10672 - 02-25-2014, 01:10 AM
RE: 89 Cabinet - by OldRestorer - 02-27-2014, 10:39 AM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 04:13 PM
RE: 89 Cabinet - by skyscraper - 02-27-2014, 04:39 PM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 10:32 PM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 10:42 PM
RE: 89 Cabinet - by skyscraper - 02-27-2014, 11:50 PM
RE: 89 Cabinet - by tab10672 - 02-28-2014, 12:25 AM
RE: 89 Cabinet - by Jake Blake - 03-10-2014, 08:23 AM
There are currently 9418 online users. [Complete List]
» 3 Member(s) | 9415 Guest(s)
