Question about tubes
No. This coating is the remnants of the getter. Getter is the tablet they put in to absorb the remnants of gasses after the tube is evacuated and sealed. Then it is heated and the getter absorbs gasses and deposits on the envelope creating that coating.
Question about tubes - by TV MAN - 02-28-2014, 10:57 AM
RE: Question about tubes - by morzh - 02-28-2014, 11:09 AM
RE: Question about tubes - by Radioroslyn - 02-28-2014, 08:27 PM
RE: Question about tubes - by Joe Rossi - 03-01-2014, 08:59 AM
RE: Question about tubes - by TA Forbes - 03-01-2014, 09:24 AM
RE: Question about tubes - by TA Forbes - 03-01-2014, 05:57 PM
RE: Question about tubes - by morzh - 03-01-2014, 06:03 PM
RE: Question about tubes - by TA Forbes - 03-01-2014, 06:14 PM
RE: Question about tubes - by morzh - 03-01-2014, 06:21 PM
RE: Question about tubes - by Eric T - 03-05-2014, 09:46 AM
RE: Question about tubes - by TV MAN - 03-05-2014, 10:41 AM
RE: Question about tubes - by Mondial - 03-05-2014, 10:58 AM
There are currently 7660 online users. [Complete List]
» 4 Member(s) | 7656 Guest(s)
AvatarAvatarAvatarAvatar
