Philco 38-12CB
Mr. Philco gave my 10 year old brother one of these a few weeks ago in Atlanta, it will be his second restoration. It's a great looking radio, and has the circuit of something much larger, sans a first rf stage. We're looking forward to it.
Philco 38-12CB - by Jayce - 02-28-2014, 06:12 PM
RE: Philco 38-12CB - by Radioroslyn - 02-28-2014, 08:06 PM
RE: Philco 38-12CB - by morzh - 02-28-2014, 09:40 PM
RE: Philco 38-12CB - by skyscraper - 02-28-2014, 10:38 PM
RE: Philco 38-12CB - by morzh - 02-28-2014, 11:11 PM
RE: Philco 38-12CB - by Jayce - 02-28-2014, 11:27 PM
Philco 91 Tuning Condenser
There are currently 9265 online users. [Complete List]
» 3 Member(s) | 9262 Guest(s)
