Philco 650B, newly refinished
Thanks Brian. I think the color on the trim and sides is just right. I am not happy with the look of the front panel. It has too much red to me. I may re-strip the front panel and use the Perfect Brown toner on it instead.
Ed
Philco 650B, newly refinished - by Ron Ramirez - 03-28-2008, 10:18 PM
[No subject] - by Chuck Schwark - 03-28-2008, 10:21 PM
[No subject] - by Texasrocker - 03-29-2008, 12:05 AM
[No subject] - by BDM - 03-29-2008, 03:02 AM
[No subject] - by Ron Ramirez - 03-29-2008, 11:11 AM
[No subject] - by Texasrocker - 03-31-2008, 11:57 PM
[No subject] - by Doug Houston - 04-01-2008, 08:52 PM
[No subject] - by Ron Ramirez - 04-01-2008, 10:02 PM
RE: Philco 650B, newly refinished - by BDM - 04-01-2008, 10:05 PM
[No subject] - by John L - 04-01-2008, 10:45 PM
[No subject] - by Ron Ramirez - 04-01-2008, 10:54 PM
[No subject] - by BDM - 04-01-2008, 11:10 PM
[No subject] - by Ron Ramirez - 04-01-2008, 11:36 PM
[No subject] - by BDM - 04-01-2008, 11:42 PM
[No subject] - by Ron Ramirez - 04-03-2008, 11:48 PM
RE PHILCO 650B - by Guest - 04-03-2008, 11:53 PM
[No subject] - by BDM - 04-04-2008, 12:45 AM
RE: Philco 650B, newly refinished - by BDM - 04-04-2008, 11:01 PM
[No subject] - by Ron Ramirez - 04-05-2008, 10:53 AM
[No subject] - by radiorich - 05-22-2008, 01:51 AM
[No subject] - by signaltracer - 05-25-2008, 07:02 PM
[No subject] - by etech - 07-05-2008, 01:15 PM
[No subject] - by Michael Dennis - 07-05-2008, 06:46 PM
[No subject] - by Ron Ramirez - 07-05-2008, 10:13 PM
[No subject] - by Michael Dennis - 07-05-2008, 10:19 PM
[No subject] - by etech - 07-05-2008, 10:58 PM
[No subject] - by etech - 07-07-2008, 03:57 PM
[No subject] - by BDM - 07-07-2008, 08:27 PM
[No subject] - by etech - 07-07-2008, 10:05 PM
[No subject] - by BDM - 07-08-2008, 08:29 AM
[No subject] - by etech - 07-08-2008, 08:53 AM
[No subject] - by etech - 07-12-2008, 10:07 AM
[No subject] - by batterymaker - 07-14-2008, 08:28 AM
[No subject] - by Michael Dennis - 07-14-2008, 08:31 PM
[No subject] - by etech - 07-18-2008, 09:17 AM
[No subject] - by etech - 07-24-2008, 04:59 PM
[No subject] - by BDM - 07-24-2008, 08:12 PM
Re: Philco 650B, newly refinished - by BDM - 09-04-2008, 10:26 PM
Re: Philco 650B, newly refinished - by Robert - 09-14-2008, 10:27 PM
Re: Philco 650B, newly refinished - by radiorich - 02-07-2009, 02:20 AM
