Today's special
Brenda
I looked at mine they are the same 50Y6 and 35L6
I looked at turn table in your first pic circled when arm comes to center it push's counter balance enough to click player off
the three idlers are rubber caps you can slide them up and off on wood dowels
Today's special - by BrendaAnnD - 02-26-2014, 11:00 AM
RE: Today's special - by klondike98 - 02-26-2014, 11:07 AM
RE: Today's special - by GarySP - 02-26-2014, 11:34 AM
RE: Today's special - by Mondial - 02-26-2014, 11:50 AM
RE: Today's special - by morzh - 02-26-2014, 11:53 AM
RE: Today's special - by sam - 02-26-2014, 01:03 PM
RE: Today's special - by gregb - 02-26-2014, 01:16 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:20 PM
RE: Today's special - by morzh - 02-26-2014, 03:26 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 03:41 PM
RE: Today's special - by morzh - 02-26-2014, 03:51 PM
RE: Today's special - by BrendaAnnD - 02-26-2014, 08:55 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:17 PM
RE: Today's special - by NostalgiaRadioTime - 02-26-2014, 11:21 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 09:03 AM
RE: Today's special - by sam - 02-27-2014, 12:54 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:49 PM
RE: Today's special - by BrendaAnnD - 02-27-2014, 02:53 PM
RE: Today's special - by sam - 02-27-2014, 03:03 PM
RE: Today's special - by BrendaAnnD - 02-28-2014, 02:01 AM
RE: Today's special - by BrendaAnnD - 02-28-2014, 01:26 PM
RE: Today's special - by sam - 03-01-2014, 10:12 PM
There are currently 9690 online users. [Complete List]
» 1 Member(s) | 9689 Guest(s)
