Philco PT-69 (Done), 38-62 (Done) & 41-22CL Resto Chronicles
I know it is not a cabinet pic but I cleaned the chassis. Have not done the caps yet and wish there was a way to get off the stains without painting..
RE: Philco PT-49 & Philco 38-62 Resto Chronicles - by OldRestorer - 03-02-2014, 07:08 AM
Philco 91 Tuning Condenser
There are currently 6974 online users. [Complete List]
» 2 Member(s) | 6972 Guest(s)
