What is your Pride & Joy radio? Owned or wanted...
GregB
I passed that radio with the mystery controller along to a fellow collector a couple of months ago. It was given to me. I gave it to him. I just didn't have room for another big consoleIcon_sad
I'll probably never see one again.
RE: What is your Pride & Joy radio? Owned or wanted... - by Art Hoch - 03-02-2014, 02:32 PM
RE: What is your Pride & Joy radio? Owned or wanted... - by MiquelonBrad - 03-27-2014, 12:10 AM
Philco 91 Tuning Condenser
There are currently 8435 online users. [Complete List]
» 2 Member(s) | 8433 Guest(s)
