Threads: 10
City: Columbia, SC
Thank you so much, Mondial. That makes much more sense.
Morzh - I went ahead and bought that one on eBay. Based on other sales I saw, I think $35 is a reasonable price. Thanks for the offer, I might take you up on it, depending on how well this one works. Wish you had posted just a little earlier
RE: Model 89 Cathedral - by skyscraper - 03-02-2014, 10:07 PM
Users browsing this thread: 43 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9953 online users. [Complete List] » 3 Member(s) | 9950 Guest(s)
