Philco 39-30 Pushbutton Removal
These pushbuttons should just slide on and off snugly. If they were replacement buttons, some one may have glued them on. Use some nail polish remover to unstick them. If they are the original buttons, they may be just stuck on from age. Use a pair of pliers to crack them apart and clean off shafts to install new ones.
Philco 39-30 Pushbutton Removal - by NV3G - 03-03-2014, 12:12 PM
RE: Philco 39-30 Pushbutton Removal - by shaler78 - 03-03-2014, 04:23 PM
RE: Philco 39-30 Pushbutton Removal - by boz - 03-20-2014, 11:51 AM
RE: Philco 39-30 Pushbutton Removal - by boz - 03-20-2014, 07:01 PM
There are currently 9918 online users. [Complete List]
» 3 Member(s) | 9915 Guest(s)
