Philco 39-30 Pushbutton Removal
The pushbuttons on my 39-25 were in such bad shape they crumbled easily and fell off. The new reproduction buttons will just slide on.
Philco 39-30 Pushbutton Removal - by NV3G - 03-03-2014, 12:12 PM
RE: Philco 39-30 Pushbutton Removal - by shaler78 - 03-03-2014, 04:23 PM
RE: Philco 39-30 Pushbutton Removal - by klondike98 - 03-03-2014, 05:33 PM
RE: Philco 39-30 Pushbutton Removal - by boz - 03-20-2014, 11:51 AM
RE: Philco 39-30 Pushbutton Removal - by boz - 03-20-2014, 07:01 PM
