  • 2 Vote(s) - 3 Average
Pilot H220 Radio @ Flea Market
Wow! A buddy in Wilmington just got a hold of the same set!!
If you want to see something interesting look at the schematic for this bear!
11 tubes plus ballast AC/DC set, FOUR 25L6 output tubes, and TWO 25Z6 rectifiers!
When you add up the total filament voltages, it is 180 volts, AND the 81973 ballast is rated at 47 volts at 300mA!!
Some serious parallel and series filament strings here!!!
Pilot H220 Radio @ Flea Market - by VntgRads - 01-26-2014, 02:36 PM
RE: Pilot H220 Radio @ Flea Market - by jontz - 01-26-2014, 02:37 PM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-26-2014, 02:38 PM
RE: Pilot H220 Radio @ Flea Market - by hsusmann - 01-26-2014, 04:09 PM
RE: Pilot H220 Radio @ Flea Market - by Jayce - 01-26-2014, 08:05 PM
RE: Pilot H220 Radio @ Flea Market - by Joe Rossi - 01-28-2014, 12:51 PM
RE: Pilot H220 Radio @ Flea Market - by morzh - 01-28-2014, 02:44 PM
RE: Pilot H220 Radio @ Flea Market - by morzh - 01-29-2014, 10:41 AM
RE: Pilot H220 Radio @ Flea Market - by Arran - 01-30-2014, 01:26 AM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-30-2014, 01:44 AM
RE: Pilot H220 Radio @ Flea Market - by Arran - 01-30-2014, 02:22 AM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-30-2014, 02:27 AM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-30-2014, 03:37 AM
RE: Pilot H220 Radio @ Flea Market - by TA Forbes - 01-30-2014, 10:17 AM
RE: Pilot H220 Radio @ Flea Market - by joybird - 03-03-2014, 07:15 PM
RE: Pilot H220 Radio @ Flea Market - by TA Forbes - 03-04-2014, 12:01 AM
RE: Pilot H220 Radio @ Flea Market - by TA Forbes - 03-04-2014, 12:03 AM
RE: Pilot H220 Radio @ Flea Market - by joybird - 03-04-2014, 08:47 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
