Philco speaker application list?
Does there exist or is does anyone have a list of Philco speaker assemblies (by part number)cross referenced to the various models they were used in?
For that matter has anyone posted a pre-war Philco parts catalog in PDF format?
Thanks in advance
Philco speaker application list? - by theblurrrr - 07-10-2008, 11:28 AM
[No subject] - by Ron Ramirez - 07-10-2008, 06:34 PM
Thanks, Ron - by theblurrrr - 07-11-2008, 03:25 AM
[No subject] - by Ron Ramirez - 07-11-2008, 06:53 AM
[No subject] - by Ron Ramirez - 07-11-2008, 07:33 PM
There are currently 9148 online users. [Complete List]
» 5 Member(s) | 9143 Guest(s)
AvatarAvatarAvatarAvatar
