Philco 16B CL find
Steve,
I too would like to know the purchase price since I have one. I used Mohawk's Van Dyke toner for the dark areas when I refinished mine.
Philco 16B CL find - by SteveJB - 02-16-2014, 05:50 PM
RE: Philco 16B CL find - by morzh - 02-16-2014, 05:58 PM
RE: Philco 16B CL find - by SteveJB - 02-16-2014, 06:03 PM
RE: Philco 16B CL find - by Jayce - 02-16-2014, 06:03 PM
RE: Philco 16B CL find - by TA Forbes - 02-18-2014, 12:38 PM
RE: Philco 16B CL find - by SteveJB - 02-18-2014, 04:51 PM
RE: Philco 16B CL find - by Art Hoch - 03-04-2014, 08:01 PM
RE: Philco 16B CL find - by SteveJB - 03-05-2014, 02:11 AM
RE: Philco 16B CL find - by PhilcoJohn - 03-05-2014, 08:44 AM
RE: Philco 16B CL find - by SteveJB - 03-05-2014, 10:37 AM
