Model 610 electrolytic condensers
Hello Kestas, I am preparing to rebuild a 610 myself. I am finishing my 70, and as soon as it is off the bench, I am going to start on it. I parallelled Morzh with the 70 and it was a tremendous help. Watch for my thread soon.
Tim
Model 610 electrolytic condensers - by Kestas - 03-02-2014, 06:54 PM
RE: Model 610 electrolytic condensers - by morzh - 03-02-2014, 08:16 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-05-2014, 10:47 AM
RE: Model 610 electrolytic condensers - by Kestas - 03-05-2014, 01:56 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-05-2014, 03:17 PM
RE: Model 610 electrolytic condensers - by Kestas - 03-05-2014, 06:32 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-16-2014, 03:52 PM
RE: Model 610 electrolytic condensers - by Kestas - 03-17-2014, 09:40 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-18-2014, 10:51 AM
