Model 60 Code 121
What is the DC voltage on the cathodes of the 6A7 and 78? Should be about 3 V to gnd. If this voltage is low then the tubes will overload easily.
Are the other tube voltages normal?
Model 60 Code 121 - by gregb - 03-04-2014, 11:36 PM
RE: Model 60 Code 121 - by Mondial - 03-05-2014, 12:29 AM
RE: Model 60 Code 121 - by gregb - 03-05-2014, 12:41 AM
RE: Model 60 Code 121 - by Mondial - 03-05-2014, 12:55 AM
RE: Model 60 Code 121 - by gregb - 03-05-2014, 01:02 AM
RE: Model 60 Code 121 - by Mondial - 03-05-2014, 12:43 PM
RE: Model 60 Code 121 - by gregb - 03-05-2014, 08:25 PM
RE: Model 60 Code 121 - by gregb - 03-06-2014, 01:06 AM
RE: Model 60 Code 121 - by Mondial - 03-06-2014, 10:35 AM
RE: Model 60 Code 121 - by gregb - 03-06-2014, 10:58 AM
RE: Model 60 Code 121 - by gregb - 03-07-2014, 01:30 PM
RE: Model 60 Code 121 - by Mondial - 03-07-2014, 10:32 PM
RE: Model 60 Code 121 - by gregb - 03-07-2014, 10:38 PM
RE: Model 60 Code 121 - by Mondial - 03-07-2014, 11:22 PM
RE: Model 60 Code 121 - by gregb - 03-07-2014, 11:55 PM
There are currently 10170 online users. [Complete List]
» 1 Member(s) | 10169 Guest(s)
