  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#63
Tim,
Excellent. Neat idea with trhe bolt also.
Just watch when you tighten it so the whole thing does not twist.
BTW what cap is it that you used here to stuff it? I mean, type, year and mfr.
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by morzh - 03-05-2014, 12:43 PM
Users browsing this thread: 25 Guest(s)
There are currently 11433 online users. [Complete List]
» 2 Member(s) | 11431 Guest(s)
