  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#64
So far, things seem solid. The cap I used is a Solen Fast metalized polyprop 6.8mf, 630v. non polarized. It is made in France. Cost $4.50 from AES. PART # C-FS6D8-630. I did this on the reccomentation of another member (Greg I think). It is working fine.
Tim
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by TV MAN - 03-05-2014, 03:33 PM
Users browsing this thread: 26 Guest(s)
There are currently 11357 online users. [Complete List]
» 2 Member(s) | 11355 Guest(s)
