What is your Pride & Joy radio? Owned or wanted...
#36
You would enjoy Alice Cooper's book Alice Cooper, Golf Monster.
He knew Dali and there are some funny anecdotes in the book about him!
RE: What is your Pride & Joy radio? Owned or wanted... - by TA Forbes - 03-05-2014, 10:09 PM
RE: What is your Pride & Joy radio? Owned or wanted... - by MiquelonBrad - 03-27-2014, 12:10 AM
Philco 91 Tuning Condenser
