I just bought another console
This Rogers is a battery set[6 volt] and someone had converted it over to 110 volt. I just hope they did it right because the last thing I need is to get in there and work on something that was worked on by somebody who knows less than I do. If it does not work out as least I will have the Rogers tubes.
I just bought another console - by Dan Walker - 03-04-2014, 11:15 AM
RE: I just bought another console - by hsusmann - 03-04-2014, 12:00 PM
RE: I just bought another console - by TA Forbes - 03-04-2014, 01:20 PM
RE: I just bought another console - by Dan Walker - 03-04-2014, 01:35 PM
RE: I just bought another console - by TA Forbes - 03-04-2014, 01:39 PM
RE: I just bought another console - by PhilcoJohn - 03-05-2014, 09:02 AM
RE: I just bought another console - by SteveJB - 03-05-2014, 09:35 PM
RE: I just bought another console - by Dan Walker - 03-05-2014, 10:30 PM
RE: I just bought another console - by morzh - 03-05-2014, 10:35 PM
RE: I just bought another console - by Dan Walker - 03-05-2014, 10:43 PM
RE: I just bought another console - by Section10 - 03-06-2014, 07:27 PM
RE: I just bought another console - by gregb - 03-06-2014, 07:48 PM
RE: I just bought another console - by Dan Walker - 03-06-2014, 09:49 PM
RE: I just bought another console - by gregb - 03-06-2014, 10:51 PM
RE: I just bought another console - by Arran - 03-06-2014, 10:59 PM
RE: I just bought another console - by Dan Walker - 03-07-2014, 12:41 AM
RE: I just bought another console - by gregb - 03-07-2014, 12:53 AM
RE: I just bought another console - by Dan Walker - 03-07-2014, 12:57 AM
RE: I just bought another console - by Arran - 03-07-2014, 05:01 AM
RE: I just bought another console - by gregb - 03-07-2014, 10:35 AM
RE: I just bought another console - by Arran - 03-09-2014, 02:22 AM
RE: I just bought another console - by Dan Walker - 03-09-2014, 10:31 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
