It's getting more complicated, LOL radio+clock+lamp+?
I agree with Jamie. By the 1950s, Philco radios had become very cheap (quality-wise). That photofinish would present quite the challenge.
I saw a 1960 Philco hi-fi in a junk store recently - an H-1616.
http://www.philcoradio.com/gallery/1960.htm#u
I was interested until I saw the condition of the lid - definitely photofinish, and very rough. Even though it was only $25, I passed.
RE: It's getting more complicated, LOL radio+clock+lamp+? - by Ron Ramirez - 03-06-2014, 08:46 AM
Philco 91 Tuning Condenser
