It's getting more complicated, LOL radio+clock+lamp+?
Photo finish is not a problem, I just have to restore one good side on the computer and then make a copy for the other 3 sides on a contact or vellum. A little glue and Tada! new photo finish.
( sounds easy, Icon_lolIcon_lol )
RE: It's getting more complicated, LOL radio+clock+lamp+? - by OldRestorer - 03-06-2014, 09:00 PM
There are currently 9140 online users. [Complete List]
» 2 Member(s) | 9138 Guest(s)
