Philco D-10A Cartridge
You have to get real lucky to find a needle for the D10A, I found one on ebay once, only once. it is virtually uno btainable, there are others still trying to find one. I hear you can switch to the D10 tone arm with the crystal cartridge instead.
Philco D-10A Cartridge - by wjheil - 03-07-2014, 11:56 AM
RE: Philco D-10A Cartridge - by Warren - 03-07-2014, 03:55 PM
RE: Philco D-10A Cartridge - by philco4me - 03-13-2014, 06:47 PM
There are currently 7911 online users. [Complete List]
» 1 Member(s) | 7910 Guest(s)
