Philco PT-69 (Done), 38-62 (Done) & 41-22CL Resto Chronicles
Yes, if you glue that resistor back together you could salvage it. Icon_lol
RE: Philco PT-49 & Philco 38-62 Resto Chronicles - by Warren - 03-07-2014, 05:13 PM
Philco 91 Tuning Condenser
There are currently 10075 online users. [Complete List]
» 1 Member(s) | 10074 Guest(s)
