It's getting more complicated, LOL radio+clock+lamp+?
Regarding missing the auction - eSnipe is your friend.
http://www.esnipe.com/
Place your maximum bid early via eSnipe and then forget about it. If you win - or if you lose - eSnipe will notify you via email.
(no, I am not affiliated with eSnipe, I'm just a satisfied customer.)
RE: It's getting more complicated, LOL radio+clock+lamp+? - by Ron Ramirez - 03-08-2014, 09:25 AM
Philco 91 Tuning Condenser
