Harvey-Wells TBS-50C Bandmaster
OK, a C model it is thanks to a gentleman in California. I don't imagine a power supply would be too easy to find so I guess I best start researching on building my own. I have the APS-50 schematic but lack the specs for the transformers.
Larry
Harvey-Wells TBS-50C Bandmaster - by rocketeer - 03-06-2014, 10:06 AM
RE: Harvey-Wells TBS-50C Bandmaster - by rocketeer - 03-08-2014, 10:06 AM
There are currently 5955 online users. [Complete List]
» 2 Member(s) | 5953 Guest(s)
