philco 71h severed RF coil winding
No there is no such thing as adhesive for gluing wires. Magnet wires are cleaned and soldered.
You can use fine grit sand paper or an Exacto. Be careful not to cut it off, just scrape.
philco 71h severed RF coil winding - by dirkbuddy - 02-19-2014, 11:24 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 06:34 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 10:36 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 11:35 PM
RE: philco 71h severed RF coil winding - by morzh - 03-09-2014, 11:27 AM
RE: philco 71h severed RF coil winding - by morzh - 06-11-2014, 03:29 PM
