The radio cloth
Hi,
It may be a long shot, but still worth asking.Original cloth is in the very good condition, just weathered. Glued to the plywood removable frame. looks new from the back side. Is there any way to have it removed and flip over? I was thinking to use some steam, perhaps.Have nothing to loose, as I restore the cabinet and will need new look anyway, so if it is damaged- be it, will get the new one, but it is not the same. Any ideas? Thanks.
The radio cloth - by fields 100 - 03-08-2014, 09:15 PM
RE: The radio cloth - by Jamie - 03-09-2014, 08:14 AM
RE: The radio cloth - by Dan Walker - 04-01-2014, 09:01 PM
RE: The radio cloth - by fields 100 - 04-01-2014, 09:30 PM
RE: The radio cloth - by codefox1 - 04-04-2014, 03:45 PM
