Harvey-Wells TBS-50C Bandmaster
Better eat your Wheaties for the SX-28A. They are a pita! Everything is buried under a bunch of other stuff. Which weighs more the DX-100 or SX-28??
Ps I sent one of my R-390A down to Chuck Rippel for him to work his magic on it. That was in Feb. It's just about done he sez it's working very well . Hope to see it soon.
It weighs in at about 85 pounds. A little bit better than the Benton Harbour Kilowatt.
Terry N3GTE
Harvey-Wells TBS-50C Bandmaster - by rocketeer - 03-06-2014, 10:06 AM
RE: Harvey-Wells TBS-50C Bandmaster - by Radioroslyn - 03-08-2014, 10:35 PM
There are currently 5911 online users. [Complete List]
» 1 Member(s) | 5910 Guest(s)
