What is your Pride & Joy radio? Owned or wanted...
#40
Owned, my 37-650. My want, a Hallicrafters SX-28.
Joe
RE: What is your Pride & Joy radio? Owned or wanted... - by Joe Rossi - 03-09-2014, 09:08 AM
RE: What is your Pride & Joy radio? Owned or wanted... - by MiquelonBrad - 03-27-2014, 12:10 AM
Philco 91 Tuning Condenser
