What is your Pride & Joy radio? Owned or wanted...
#41
They are back ache and a pain to work on. The 28A is a bit better. Hallicrafters did release so factory mods to improve the nl and stability. Was just reading about them in CQ from '55. On the plus side they do sound good!
Terry N3GTE
RE: What is your Pride & Joy radio? Owned or wanted... - by Radioroslyn - 03-09-2014, 03:10 PM
RE: What is your Pride & Joy radio? Owned or wanted... - by MiquelonBrad - 03-27-2014, 12:10 AM
There are currently 8866 online users. [Complete List]
» 2 Member(s) | 8864 Guest(s)
