Restoration Questions on my 37-116
Good question. 1937 was the year that Philco switch over to rubber from the older cloth cover rubber wire.
On your coil is the outside winding the open one??
I'm sure you'll really enjoy this set once it all back together!!
Restoration Questions on my 37-116 - by 462ron - 03-09-2014, 05:47 PM
RE: Restoration Questions on my 37-116 - by Radioroslyn - 03-09-2014, 05:58 PM
RE: Restoration Questions on my 37-116 - by morzh - 06-01-2014, 10:36 PM
RE: Restoration Questions on my 37-116 - by morzh - 12-11-2014, 10:56 AM
462ron - by 462ron - 02-20-2022, 04:51 PM
462ron - by 462ron - 04-19-2024, 11:20 AM
RE: Restoration Questions on my 37-116 - by morzh - 04-19-2024, 05:20 PM
462ron - by 462ron - 06-28-2024, 07:32 AM
RE: Restoration Questions on my 37-116 - by morzh - 07-04-2024, 11:18 AM
