Help! Philco knowledge required.
By the way, I trawled the gallery here and elsewhere. It is probably an export, has no model number inside or out, carries five valve [US tube] 19, 30, 32E (two), 1a6? and finally the schematics pasted on the inner has been torn off by some....... Icon_confused
[No subject] - by englishradioman - 07-12-2008, 06:49 PM
[No subject] - by Michael Dennis - 07-12-2008, 08:41 PM
[No subject] - by Ron Ramirez - 07-12-2008, 09:10 PM
[No subject] - by exray - 07-12-2008, 10:10 PM
[No subject] - by Michael Dennis - 07-12-2008, 11:32 PM
[No subject] - by englishradioman - 07-13-2008, 09:53 AM
[No subject] - by Ron Ramirez - 07-13-2008, 11:31 AM
[No subject] - by englishradioman - 07-13-2008, 12:36 PM
[No subject] - by Michael Dennis - 07-18-2008, 10:36 PM
[No subject] - by englishradioman - 07-19-2008, 05:43 PM
[No subject] - by Michael Dennis - 07-19-2008, 08:27 PM
[No subject] - by exray - 07-20-2008, 07:09 AM
[No subject] - by englishradioman - 07-20-2008, 08:27 AM
There are currently 6990 online users. [Complete List]
» 1 Member(s) | 6989 Guest(s)
