Wards 62-418 Movie Dial set..
I have been eyeballing a radio just like this on sitting at a friend's place of business. Also, there was one of these at that auction I went to last month. They are a BIG table radio!
Wards 62-418 Movie Dial set.. - by Jamie - 03-09-2014, 05:13 PM
RE: Wards 62-418 Movie Dial set.. - by Jamie - 03-09-2014, 07:19 PM
RE: Wards 62-418 Movie Dial set.. - by Jayce - 03-09-2014, 07:52 PM
RE: Wards 62-418 Movie Dial set.. - by radiohenry - 03-09-2014, 07:59 PM
RE: Wards 62-418 Movie Dial set.. - by Jamie - 03-09-2014, 09:00 PM
RE: Wards 62-418 Movie Dial set.. - by radiohenry - 03-10-2014, 07:50 PM
RE: Wards 62-418 Movie Dial set.. - by Jamie - 03-11-2014, 06:40 AM
RE: Wards 62-418 Movie Dial set.. - by sam - 03-11-2014, 12:19 PM
RE: Wards 62-418 Movie Dial set.. - by Jayce - 03-12-2014, 08:41 PM
RE: Wards 62-418 Movie Dial set.. - by y2kbruce - 03-13-2014, 04:18 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
