useing Correct color for Radio
Thanks Guys. I used a gloss clear laquer and mixed the toner with it. I sprayed it with a spray gun and compressor. I still l need to put a few coats of clear on it but first I need to put a dark toner on the bottom and the face plate, etc. I sprayed that piece of wood underneath it with the dark I have but it doesn't seem like it is quite the right color for it. Am hoping someone can tell me for sure.
useing Correct color for Radio - by Warren - 03-09-2014, 05:59 PM
RE: useing Correct color for Radio - by morzh - 03-09-2014, 08:11 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 08:31 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 11:06 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 11:55 PM
RE: useing Correct color for Radio - by morzh - 03-10-2014, 10:29 AM
RE: useing Correct color for Radio - by Jamie - 03-10-2014, 02:19 PM
RE: useing Correct color for Radio - by morzh - 03-10-2014, 03:33 PM
RE: useing Correct color for Radio - by Warren - 03-10-2014, 05:51 PM
RE: useing Correct color for Radio - by Warren - 03-15-2014, 07:27 PM
RE: useing Correct color for Radio - by morzh - 03-15-2014, 09:07 PM
RE: useing Correct color for Radio - by Warren - 03-15-2014, 11:25 PM
RE: useing Correct color for Radio - by gregb - 03-15-2014, 11:34 PM
RE: useing Correct color for Radio - by TheBakery - 04-28-2014, 02:39 PM
Philco 91 Tuning Condenser
There are currently 10168 online users. [Complete List]
» 2 Member(s) | 10166 Guest(s)
