If You Need To Learn About Radio Repair..
#42
These days it's fast! When I got my Novice ticket it took month before I got it in the mail.
Good Job John! Do go for the Gen as HF is more fun than VHF/UHF. I personally like to build and experiment the HF stuff isn't near as critical.
Terry N3GTE
RE: If You Need To Learn About Radio Repair.. - by Radioroslyn - 03-10-2014, 08:30 AM
Eico 232 VTVM Schematic
There are currently 8766 online users. [Complete List]
» 2 Member(s) | 8764 Guest(s)
